Out of stock already XD.
Yeah I'd much prefer to build my own system and water cooling but for people who don't have experience and are beginners it’s a fantastic solution.
I would definitely update the site with a few pictures of the system and WC in action as I can imagine it's a bit of a turn off with the Antec 900 empty case in every section.
Wet the buyer’s appetite!
RoEy
D-Tek Fuzions causing the problem.
Should not be long at all before these come in stock as they are on the way.
So very tempting, pretty expensive though and the wife would kill me![]()
Why not use the new XSPC Edge instead? It's getting extremely good reviews and is less restrictive and also cheaper than the Fuzion.
i remember seeing "ocuk will never stock watercooling gear"![]()
will u not be afraid it could cause more rma problems like leaked water cooling on some parts ?
Hi there
Yep it will soon be an option in there along with other updates as well.
As above, sell the kit as a separate part, for 'less' than parts individually if you don't mind!
