The 363 is the 361's replacement - the 363 has HDMI switching, the 361 does not. Either way, you need to spend a bit more if you want sound via HDMI. Optical is the best option, but some HD-DVD's will only have 2 channel sound.
the 761 with nsp110 speakers is better then the av63 as the yamaha 761 supports sound over hdmi so as long as the source decodes hd sound and sends it as pcm youll have hd sound
