How to clean my pc
Permabanned
28 Oct 2006
Bournemouth
Basically i was just having a nice game of portal, then all of a sudden it closed bleeped up a message and then proceeded to shut me down. My psu fan is making a clicky noise due to dust, and im assuming every other fan in my case is dusted up as well. I cbb to get out the hoover, so are there any relatively cheap easier alternatives?
Yeah, just researched and found that this 'air' costs about a fiver to get to me. I'll think I'll just whack the hoover in there tomorrow and see if it works at making my fans sound smooth
"air" in a can, usually isn't, it's loaded with butane (so someone here said, but it's some kind of propellant with a better compressability), and if you shake them or hold them at funny angles, they will belch it out. Most such things are solvents and will eat silicon in a flash, so be careful...a drop here and there wont penetrate before it evaporates, but a massive flood of the stuff might just turn your day bad. Best not to smoke too.
Speaking of smoking......if you do, and do it a lot round the PC, you may need to physically yank some of the dust bunnies out of the fans. A small brush to disturb dust is useful in all cases.
Finally, try not to emulate my brother and hoover the NB heatsink off!
Ive heard that vacuuming can cause damaging amounts of static and destroy components... Diddn't stop me though, had the vacuum in, cleared out the CPU and GPU, 20C drop in temps for both......
a Small 1/2" brush and some anti static screen wipes do the trick here however if you can get commpressed air it's great for blasting clean the bearings of fans
also when finnished cleaning the fans a couple of drops of light machine oil in the fan bearings will also help quieting them down a bit and allow them to run smoother.
Toilet roll/tissues is pretty easy if you have nothing else to hand (the vacuum cleaner was broken hence the need to clean to start with...)
I just use a paint brush for removing dirt. Works wonders and you don't have to worry about lint / static / that really cold stuff from compressed air canisters.
hoover or can of air it really good..... told my mate that and he grabbed his paintball gun tank which had 2000psi in it and let it rip.... lol dust clouds everywhere!!!!
