The worst bit is pressing the power button for the first time, and absolutely nothing happens.I've been there many times.
Thats what im worried about it![]()
I know exactly what you mean, also those tiny mobo headers a real pain. Whats worse is then discovering that new mobo is faulty and you're going to have take everything out again wait another day and rebuildFor me the best bit of building a PC completely from scratch is seeing all the boxes sitting on your desk waiting to be opened.
Simple, turn power supply ON, and retry.![]()
i did that and set a pen drive on fire!I would say connecting the headers to the motherboard is the hardest bit. For my first build, i got the front USB ones attached the wrong way. I booted up the computer, everything worked fine and installed windows. Later on when i plugged in a flash drive, it didnt work. I wasn't sure what was wrong so i tried plugging in a gamepad, which promptly started shaking like mad and wouldnt stop. I then figured out that i had put the USB header the wrong way round. That lesson cost me £35 worth of damage in total
Impressive although not as good as my first pc, I didn't realise that I needed to apply TIM.I would say connecting the headers to the motherboard is the hardest bit. For my first build, i got the front USB ones attached the wrong way. I booted up the computer, everything worked fine and installed windows. Later on when i plugged in a flash drive, it didnt work. I wasn't sure what was wrong so i tried plugging in a gamepad, which promptly started shaking like mad and wouldnt stop. I then figured out that i had put the USB header the wrong way round. That lesson cost me £35 worth of damage in total
Built pc turned it on, it turned off strait away then I decided to hold down power button to try to get it to stay on...
mistake. smoke from cpu and dead mobo/cpu![]()
