Is there known compatibility issues between these 2? Because I simply cannot get XP to install using this memory in this board. Memtest reports thousands of errors and I cannot get past the initial xp setup without a blue screen, or a restart.
I have found, however, that slowing the memory down to DDR200 speed (instead of DDR400) I can get past the XP setup and I can install XP, but then when XP boots, I get another blue screen just after the cursor appears. Is there any solution? and if not, can anyone recommend good memory for this board?
oh and just to rule out the memory being faulty, I have used this memory for almost a year in my A8V Deluxe without any problems.
Cheers.
Cheers.
