Pint = over 500mL
Glass of wine = closer to 75~125mL
Pour a pint of wine down your throat you'll get the same effect
Bubbles to make the alcohol get to your bloodstream quicker IIRC - hence why Champagne tends to have more of an effect than wine.
hes not making it up & you're along the right lines there AFAIK - tis something to do with gunpowder! - though it is 'degrees' proof not '%' proof
Another factor that facilitates the absorption of alcohol from the small intestine is whether the beverage mixer consumed with the alcohol, or the alcohol itself, is carbonated or not. Carbonated beverages are absorbed more readily than noncarbonated beverages. The rapid intoxication produced by champagne, in contrast to a noncarbonated wine with an equivalent alcohol concentration, is due to the fact that champagne is carbonated.
You're how old and you don't understand percentages?
i don't understand how alcohol % is measured.
for example, a can of carling has 4.1% in it. is that the WHOLE can or just a certain dose? if a vodka bottle claims to have 40% and you take a shot, does the shot have 40% in it or just the bottle as a whole?
It's not just halves.... you can drink 7.5 bottles of vodka and only drink the top quarter too.If you were to get 5 bottles of vodka and only drink the top half of each you won't get drunk.
would that not be the proof? (so 60% abv)
You wouldn't believe how many people believe that adding drinks together increases the alcoholic 'strength'.This reminds me of an old school friend who was boasting he created an 80% cocktail. I thought he had just got hold of a polish bottle of vodka or something and blagged it was his, but no.. his cocktail consisted of JD, Kahlua and something else, and he added the %'s together.![]()
When you mix ethanol and water you will not get the same total volume of liquid eg 10mL of water + 10mL of ethanol will not give you 20mL of mixture.
It's to do with the size of the 'chemical things' (can't remember the right name, compounds maybe)errrr....
He is correct. Try it yourself![]()
40% means its 40% alcohol and 60% non alcohol !
God know's what they teach kids in school these days![]()
Spec me a Brain
Rest of you lot, get off your high horses, must be nice to know everything![]()
