- 3 Jun 2008
Those of you with this board are probably also ****** that Suspend-to-RAM (aka S3) doesn't work. Anyway this can be fixed by flashing a modded bios found here. Speed step and advanced power features are also enabled so it is worth it even if you dont use STR.
STR really is great, all the fans go off including the PSU but the system is still available within 2 seconds!
hope this helps someone.
