Crucial RMA
21 Apr 2007
Hi, i think my ram has failed but before i state that it has the reason i have come to this conclusion is because my pc would hang launching games, reset randomly, sometimes wouldnt boot, or screen would become severly artifacted. I've removed one of the sticks and now pc is fine so im guessing one is faulty.
The ram i have is
http://www.overclockers.co.uk/showp...0C3 667MHz Dual Channel Kit (BL2KIT12864AA663)
I was wondering, i purchased my ram just over a year ago so would i be able to still RMA it? is it even still covered by warranty? and this damage hasnt been caused by me i havn't overclocked ram or anything like that been running stock for around a year but started having problems couple months back with it and now it seems it has completely failed.
It's only one stick that has failed im presuming based on fact once i removed the one the pc is now running fine.
Thanks for any input!
The ram i have is
Module Size: 2GB kit (1GBx2)
- Package: 240-pin DIMM
- Feature: DDR2 PC2-5300
- DIMM Type: UNBUFFERED
- Speed: DDR2-667
- Voltage: 2.2V
- Memory Timings: CL=3
- Warranty: Lifetime
:D
Best thing to do is run a memery test on then. Then if any errors which there most probaly will be, then its aint working right. And the warranty is lifetime so that should be alright.
~Slash
~Slash
Can i send 1 stick back instead of both? havnt run memtest but its obvious one stick has completely broken.
