Poll: ** Age of Conan PvE Guild EU-Dagon **
What guild name?
  • Cromputer
    Votes: 35 28.2%
  • Does Not Crompute
    Votes: 89 71.8%
  • Total voters
    124
why i cant hear any npc voices i use to hear them before the reinstalled the game cant hear them anymore
edit : nvm fixed it my self
My brother picked this up today. So far so Funcom, registration has been down all day so he can't even create an account.
ok, who do i see to get an invite to the guild or where do i sign up ?
Either me (Atum), Chel, Jimbu or Ragu. Send us a tell ingame or put your nick here.
Update Notes:
General
* By popular demand we have added a new "Level up" sound effect.
* Player Building tooltip displays correct predecessor information now.
* Fixed some randomness in when you would see the tutorial popup flags.
* Trading with another player will no longer cause traded items to appear in the incorrect inventory tab.
* Removed the commandline to setting hotkeys since it was only intended to debug hotkeys before the GUI was there
* The "usable items only" checkbox with traders should now work as intended.
* The facemarking 'Freckles' should now work for new characters.
* Minor issue with tradeposts and setting up items for auction has been resolved.
* Corrected several animations for mobs as well as NPCs during cut scenes.
* Increased the xp gained from group normal mobs and group bosses.
* Players will now be able to experience the destiny event in the Field of Chiefs.
* New voice over for some of the events in the Capture The Skull minigame.
* More client and server crashes resolved.
Combat
* Evadebonuses are now applied when you are being attacked from behind.
* Players with Shield of the Risen will not be affected by secondary effects from combos.
Chat
* If you drag a chat window with only one tab in it over the tab-bar of another chat window it will now be added as a tab to that window (inserted before the tab that the mouse is over in the "target" window).
* When pressing enter the input focus will by default go to the last active chat tab rather than the selected "default tab". The previous behaviour can be achieved by checking the "Default Window" menu entry for one of the tabs.
* Tweaked the areas you click to resize the chat window to make them easier to use.
GUI
* Guild Feats: It should now show a scrollbar.
* Buff icons no longer get stuck on after teleporting or talking to an npc.
* Resolved a GUI related crash when clicking on the bank (broker).
* Fixed an issue causing buffs placed outside the currently visible area of shortcut bars to still flash when ending cooldown.
* Whisper replies now always go to the chat tab you sent the original message from, in addition to the tab that is subscribed to the "Tell" channel.
* Added some missing class icons used by the team/raid GUI.
* Raid leaders now have an orange name in the raid GUI.
* Removed an unused hotkey (Show chat config).
Items
* The weapons should now always appear sheathed in the character selection screen.
* Potions: Fixed an issue with the stamina potion 'Old Redrouse', it will now get consumed when used.
* The 'Nemedian War Flail' has been renamed to 'Nemedian Mace'.
* The Rending Strike and Rupturing Strike proc from some equipment will no longer linger on the target indefinitely.
Tradeskills
* Gemmed items should now work (giving bonuses) and viewing them should no longer crash the client.
* Becoming a Woodcutter should no longer erroneously tell you that you've learned the 'Evading Roll' combo.
* Harvesting: Script now keeps track of the persons that are using a resource node. This prevents the user from trying to use it twice and thus not harvesting anything at all.
NPC
* Monsters 4 levels or higher will now correctly have increased evade and immunity chance.
* Resource gathering npcs will now display the '?' over their heads when you have the goal and items to return to them.
* Princess Akivasha now attacks back when attacked in Sanctum of the Burning Souls.
* The encounters in the Armsman's Arena should be less chaotic.
* Demonic Pict will no longer try to cast spells at players without being able to do so.
* The Quest NPC's for the Frost Swamp, Imerian Ravine and Oasis of Zaara have been shuffled around in the Resource and Building playfields to make it easier for players to spot them amongst all the other tradeskill NPC's
Pets
* Movement speed of pets have been increased both in and out of combat.
Playfields
* The Armsman's Arena is now a private instance.
Archetypes
Mage
* Contract of Protection, Protection of Set, and Runed Flesh now have 1 hour cooldown. While any of the three is active, the player will temporarily receive a 'Weakened Protection' debuff indicating if the maximum amount of absorbed damage has been expended until the shield refreshes.
* The maximum damage Protection of Set and Runed Flesh can absorb before failing has been increased by 50%
* The Archmage feat has been moved to the 2nd tier of the Mage general tree
Player Characters
Demonologist
* The base splash damage inflicted by Fires of Gehenna has been increased from 10% to 30%
* The base splash damage inflicted by Shockstrike has been increased from 15% to 20%
* The base column radius of Hellfire Stream has been increased by 1 meter
* Hellfire Stream and Shock have received a minor damage increase
* Inferno of Amher and Shockblast have had their cooldown reduced by 0.5 seconds
* The splash damage bonus of Discharge Shockstrike has been increased to 100%
* Swift Shockstrike now additionally increases the damage of Shockstrike by 1/2/3/4/5%
* Shock now has 35% splash damage, up to 3 targets and 3 meters from the primary target
* Shockstrike and Shock have had their base chance to crit increased
* The scaling of the Shock spell has been corrected, leading to a damage increase at most levels
* The bonus of the Lingering Flames feat on the Incinerate effect has been increased from 30% to 250% at maximum rank
* The casting time of Detonation has been reduced from 3 seconds to 1.5 seconds
* Living Thunderstorm and Living Firestorm now correctly use a percentage-based manacost
* Living Thunderstorm should now correctly appear in the hostile spells tab
* The casting time of Infernal Knowledge, Diabolic Insight, Mark of Dagon, Shield of Infernal Flames, Abaddoron Warrior, Mystic Suppression, Cursed by Hell, and Cursed by the Heavens have been reduced by 50%
* The beneficial effect of the Pact of Earth Walking spell has been increased from 200% to 400%
* Pact of Earth Walking is now instant cast
Necromancer
* Fixed a bug causing the available pet point indicator in the pet list GUI to sometimes show 0 points available rather than the actual number.
* Spellweaving can be cast and cancelled normally now.
Dark Templar
* 'Mystical Bane' combo: The damage dealt by the Incinerate Ether component of Mystical Bane combos will now correctly deal 50% of the mana burned to be consistent with other power burn effects.
Priest of Mitra
* Revivication Feat: The healing effect granted by the Revivication feat will no longer fail to trigger if the Priest is level 65.
* Condemnation now receives a partial cooldown if the spell does not complete channelling.
* Purification procs will no longer incorrectly apply a cooldown to Condemnation.
Barbarian
* Barbarian's should no longer be unable to attack or move directly after performing any rank of their 'Savage Rage' combo.
* 'No Escape' combo should now always give you a cooldown when used and you will always get disarmed.
Herald of Xotli
* 'Fire Lance' combo now only needs 3 attacksteps to execute so it can be triggered faster. The combo now also hits targets a bit further away than before making it more effective.
Conqueror
* Combo 'Throat Slash' has been corrected to be a spear attack instead of a ranged attack.
Tempest of Set
* Mark of Set now has the correct casting animation and effect for all ranks.
((continued in next post))
__________________
Oliver 'Tarib' Kunz
Senior Community Manager
Tarib
View Public Profile
Send a private message to Tarib
Find More Posts by Tarib
Unread Today, 10:24 Tarib is offline #2
Tarib
Tarib's Avatar
Default
Quest
* Updated quest journals of "Phoenix of the East" to reflect new position of NCP General Tatius.
* Fixed animation problem where Arias could not decide to sit or stand during conversation.
* Ninus and Si-Khu will reliably spawn when logging out near the Temple of Mitra.
* The access quest for the Armsman's Arena revamped.
* The Phoenix of the North: Resolved an issue with Mithrelle not standing up if not viewing the small cutscene.
* Resolved an issue that forces quests to not update on zoning.
* Wagon Wreck: Revamped with a new quest goal.
* The Poisoned Cup: Revamped with more interaction with the objects in the quest.
* The Curse of the Werewolves: Slight enhancement on quest targets.
* Wolf Hunt: Slight enhancement on quest targets.
* Greater Prey: Slight enhancement on quest targets.
* Death to the Vanir: Slight enhancement on quest completion.
* Finding Safe Passage: Revamped with a new quest goal.
* Captives of the White Hand: Revamped with a new quest goal.
* The Cheiftains Vengeance: Revamped with a new quest goal.
* Wolves at our Throats: Revamped with a new quest goal.
* Bartholomo's Wife will respawn more often, if you happen to kill her before required to by the quest 'The Awakening III'
* It should be easier to deal with Renton's Corrupt Friends when doing the quest Awakening II
* Sanctum of the Burning Souls: The boss drop 'Bloodtainted Hoop' will no longer end up in the quest inventory.
* Field of the Dead: 'Fur of Bloodclaw' will no longer end up in the quest inventory.
* Tarantia Noble: Improved these quests: Bloodroot, Concealing the Chinks, Purging the Fallen, Source of Contagion.
* The Lurking Horror: The Area marker is now set on the map
* Pool of Black Blood: Quest now updates when you kill the Lesser Black Ones as well.
* The Slave Rebellion: Replaced radius with a fixed waypoint for one of the goals.
* Fetching Fungi: A waypoint will now lead the way to Sanctum, and to the mushrooms inside.
* Lifting the Curse: Waypoint will now lead you to the Sanctum of Burning Souls.
* The Sinister Sepulcher: Orb is now destructible, and all the Undead Thralls in the area will update the quest.
* The Black Skulls: Corrected some wrong waypoints.
* Fleet of Mouth: Cycaelus has upped the difficulty. You now need to beat his record on half the time you needed before
Finally!! Socketing is fixed :D Looks like demo's got a nice boost too so no more complaining!! :p Armsman Arena being private is just pure awesome too!
cheers mate ill be on later tonight
Main toon is 'Chakras'
Alt toon is 'Divx'
send me a tell before inviting so i can sort out and leave my current guild
cheers
I've hit 54 and im now starting to feel the grind, the game also feels incredibly boring. Coupled with the fact there are so many bugs huge respawn times for bosses, public dugeons I think im going to ditch this game, at least untill it has matured to the point i can actually enjoy playing it. Btw im in nexus hornets under the name creomortis
Gah nerfed Dark Templars only good attack, wasn't even that special =/ Class is complete crap, worst DPS in the game and Guardians are preferred tanks. Life tap doesn't do much either, I think it's the paladin of WoW
Anyone fancy taking over? Can hardly be bothered to play any more, might start a barbarian or continue with ToS.
NOOOOOO! * Potions: Fixed an issue with the stamina potion 'Old Redrouse', it will now get consumed when used.
I loved that :(
And can the OP move me from Demo to Assassin?
ditto, and i only discovered that attack yesterday :o, never used it before.
i think the gem socketing is still fubared according to a post after the patch notes. and there is some whinging about gathering being a bit more temperamental, apparently if you get interrupted you can no longer gather from the node. least they're trying!
edit: the dark templar change only changes the mana drain element of the spell rather than the damage portion or am i reading it wrong?
Basically the talent added shadow damage equal to 100% of the mana damage caused, it was probably our only decent combo worth spending the effort pressing the buttons and stamina to pull off.
Meh, addicted to UO again anyway =p
Just to let you guys know im heading off to Download in a bit so i wont be on for a week or so since i have a load of stuff to sort out when i back! I have not quit so dont kick me from the guild :P
