vista upgrade on a laptop
20 Jun 2007
Nottingham
I have the opportunity to get a cheep copy of vista HP upgrade. and am looking to upgrade my laptop with it.
now as I understand, I need a install of XP. which I have, but does it have to be retail?? which it isn't obviously.
also I don't have an XP CD, to pop in during the install, I only have the Toshiba recovery disc, is this going to work??
OEM is fine to upgrade from.
As for the upgrade, it's changed since XP. You now upgrade from an activated installation rather then just "popping a disc in".
Burnsy
Burnsy
dose this mean I have to do a fresh recover of my XP install to install Vista each time I want to start again??
also is the upgrade bound by the same OEM rules or is it more like retail
A) Yes, or image the installation using True Image or something
B) The upgrade is an extension of your rights in the qualifying product. So, if you upgrade from a retail version, it has the same restrictions as OEM and the same for OEM.
Burnsy
what spec is the laptop?
if you want to use it for more than browsing the internet & winamp, then don't bother if it's not got dual-core and 2gb+
I used to do a lot of cad work on it, its got a good duo core but its only got 1GB (the system is less than 2 years old so before memory got really cheep), was planing to get a 4 GB kit of the MM. but missed to the boat. :o
it all went hand in hand really,as I would have to upgrade to make cheep copy of vista worth wile.
I think one copy of vista on my desktop is all i need. :p
