MSI P45 Platinum Beware!
3 Nov 2005
I have just installed my new board and have found that my swiftech apogee waterblock doesn't fit due to that copper pipe on side of the cpu socket.:mad: So cheesed off!
I think I will have to as just looked at the Asus P5Q Deluxe and that would have the same problem:(.
What temp improvement do you think I would get over an apogee?
Cheers
Which Apogee? The GT or the GTX?
You'll get maybe more than a 5c drop with a Fuzion v2 over a GT, especially if you get the quad insert for it.
