- 23 Apr 2007
- Cardiff-ish, Wales
Hi guys,
just bought a Gigabyte GA-MA78GM-S2H for my wifes ageing PC and it's not seeing the IDE HDD when I try installing Vista Ultimate 32bit version. I've got an IDE DVD-RW as well so I've bought an IDE to SATA convertor since the Mobo only has one IDE port.
I connected the IDE to SATA convertor to the HDD first then powered up. I get the following message:
"SATA is found running in IDE mode!"
It then asks if I want to set SATA to AHCI mode. I've tried both modes but when I get into the Vista install screen there are no drives for me to choose to install to.
I've also tried swapping the IDE to SATA convertor to the DVD-RW drive and connecting the HDD directly to the IDE connector on the mobo. I still get the "SATA is found running in IDE mode!" message and again, the HDD is not found in Vista.
Any ideas???
Cheers,
Jed.
Any ideas???
Cheers,
Jed.
