Rollercoaster Tycoon 3 1920x1200?
Navigate to C:\Documents and Settings\YOUR USERNAME\Application Data\Atari\RCT3 and open the options.txt file. The first line should read something like this:
Resolution 1024 768
You will want to change it to:
Resolution 1920 1200
I found that if you have a really short, narrow main footpath, maybe 15 squares long and just 1 wide with all the ride entrances, ride exits and stalls on that 1 short path, you can charge ridiculous prices for even the rubbish rides. It works best with about 7 or 8 rides and after a while, you can charge over £5 for a go on a slide.
Right i'll try that lol
