- 18 Oct 2002
- Harlow, Essex
ill give ya £40 to remove my 2.0 engine and put in a 2.5 v6![]()
why stop at the 2.5 you might aswell go for the 3l
Good vid
cool vid but what gearbox are you using? Have you used a box from the 1*2 or a valver one?
The circlips in the valvers could either last forever once you replaced it or come out the next day, so unpredictable. Welding doesn't work as you've found out.. some bloke was bolting them in on the valver forum which seemed to work.
Bet it's quick![]()
172 boxes don't come up for sale often and they tend to be expensive
there's also the issue of mounting it, ideally u need to use the 1*2 battery tray, but I can't cause I have ABS
wiring wasnt too bad actually- just can't get the rev counter to work
