I never played online before, only over networks.
Whats the difference between ladder and non-ladder?
You guys playing just D2 or D2+LOD?
Hegde, i'm on an expansion character![]()
Ah dang!, is it possible to make a non expansion one? then upgrade it later
Yes. When you install LOD you get the option to convert your character to expansion.
Ok mate thanks, i couldnt remember.
Once installed can you make non expansion chars though?
My pala is up to andariel, only lvl 13, you playing in a game i could join Uta, just for a chat etc while i play through?
.You can join his normal games
And you can join mine. which is good, cause i need mephisto runs(i've done baal, just need xp! level 22)
