I can't access Windows!!! Am I going to lose everything!??! This is a disaster... I want to cry...!!
OK, thanks. But how do I enter these commands then? By booting off the Vista disk, and going to 'Repair Your Computer', and going through the 'System Recovery' screen, it then gives me the option of opening a Command Prompt window. Doing this gives me a command prompt with X:\Sources written there, which I can change to C: but then what?Take a deep breath......
Then google fdisk/mbr or fixmbr.
Linux writes its bootloader ( GRUB ) to the MBR. When you remove Linux, GRUB remains in the MBR and gets confused when it can't find the Linux partition that you deleted. You want to get rid of it and restore a Microsoft MBR. That's what those two commands above do.
And will I lose any of my files doing this?
