Antec 900 Revision?
9 Jun 2008
Hi guys, i've been trying to think which case to go for. I could go for the Antec 1200, but go for an 8800GT or i can get an Antec 900 and use the money i saved to get a better graphics card.
My question is though, does anyone know which version of the Antec 900 OcUK stock?
I've read on the internet that there were some revisions. And that the latest version includes wire management holes readily made. Since i'm not the DIY type when it comes to case mods has anyone bought an Antec 900 from OcUK know if their case came with wire management holes?
Thanks,
Dan
I brought a 900 on thursday, didnt notice any management holes, apart for the fans, but it wasnt too bad
I just tidied the cables up when i had finished with it :)
Oh right, may have to try persuade my family member to help me out with some DIY then :P
I might put some dust covers for the fans too, it may help with the well known dust problem of the 900.
Hmm, I think I'd forgo a few beers and get the 1200 :)
It's an incredibly hard decision, i'm even considering the 300 now. All the great remarks i've read about it. I just want some thing with good cooling and good cable management. So i'm rattling my brain trying to think which one i should go for...
i think you should go for the 300. if edgey was around , he would say the same. he loves it . just look at his thread "antec 300 more pics" to get an idea of what cable management can be done. though you may want to drill some cable management holes in the mobo tray anyway. the 300 also has dust filiter which according to edgey is working great.
thumbs up from me.
(and if you dont like it you havent wasted to much money - just remember to buy extra fans as it only comes with the exhaust fans , not the front two)
