Yeh, but reread my original post please. I cant make it any simpler. I would like to DOWNLOAD sp3 for XP, but not the version meant for networks.
Great thanks.
Is it actually worth installing? Any known issues or bugs?
Its always worth installing a Winblows update, as it plugs one of the many holes it has.
When M$ release an update containing security fixes the hackers look at which holes its fixing, and these become the next target points for them. So if you dont update you are very much at risk because M$ has told those that didnt already know where the weaknesses are.
tinfoil-hat much?
tinfoil-hat much?
Should I just add you to my ignore list now? Are all your posts going to be of such a rubbish standard?
