- 31 Dec 2003
- Barrow-In-Furness
Very fair comment, i'm guessing the cisco IP phones are very good then? I've talked about VoIP before but we're talking lots of extensions.
I'm still not following you on the switch capacity thing.. regardless of what vendor you use you will need for example.. 500 wired devices, and then 50 access points and however many controllers. The total port count will still be the same..
I have a feeling i'm missing the point with the 6500 stuff - I really don't know anything about it
Is there not a realiability issue with using something like a 6500 on an access level, in that if the controllers break you'll lose everything rather than just losing one switch? (Although this isn't a common occurance...)
(Go easy i'm trying to learn ha-ha)
