Hi all,
I built a PC for my mate over the weekend and I'd just like to see if the CPU temps he's getting are ok. It's the stock Intel HSF he's using as he's not going to overclock initially.
He had several parts already like CASE, GPU, PSU, DRIVES.
Specs:
Intel E8400 3.0Ghz
ASUS P5E X38
Corsair 2GB DDR2 XMS2-6400C5 TwinX
Nvidia 8800GT 512MB
WD 250GB SATA2 16MB Cache
Case unsure of but is small - 2 80mm rear fans - 1 92mm front fan.
EZCool PSU 700Watts
Testing Software:
Orthos
CoreTemp
I removed the stock thermal paste and applied Arctic Silver 5 Thermal Compound. When building the PC I have ensured that the cable management was as good as I could possibly make it. I've used plenty of tie wraps so it does look extremely tidy. The stock HSF is on correctly, all 4 pins are through and is sitting level.
I used Orthos to test the CPU for 40 minutes and the temps went up to and stabilised around 69-71 degrees, which I thought were a little high. As soon as I closed Orthos the temps went down to 59-60. The system now idles at around 52-53 when doing everyday tasks like downloading etc. Gaming though (cod4), temps were around 65-68.
Does this seem normal for stock cooling and is it ok running at these temps for long periods of time?
I have suggested that he get a bigger case with better cooling, i.e. 120mm fans and I’m convinced it will dramatically reduce his temps.
Hope someone can help,
RoEy
Specs:
Intel E8400 3.0Ghz
ASUS P5E X38
Nvidia 8800GT 512MB
EZCool PSU 700Watts
Testing Software:
Orthos
CoreTemp
RoEy
