Volkswagen re-releasing the Scirocco
[TW]Fox;11897442 said:
I see and the Corrado was a small hatchback?
I dont understand your point. I assumed you were commenting on the bit where someone said the scirroco would be nicer with the 3.2 engine in it and as the corrado was the predecessor to this car, I was pointing out that the big engine in a small car can be ok.
By todays standards i would say that the corrado is a small hatchback
But the 2.9 in the Corrado was a lightweight narrow angle V6 was it not? Whereas VAG's current 3.2 FSI is a conventional, heavier and larger engine.
whats that got to do with me saying the corrado was a good handling small car with a big engine?
whats that got to do with me saying the corrado was a good handling small car with a bigh engine?
How about... everything? Surely it's obvious the point I am making - heavy large capacity engines upset the balance of smaller cars. Therefore the fact that the 2.9 was a light, narrow angle engine is pretty much 'everything' to do with what you said and goes some way towards explaining how the Corrado bucked the trend (If it even did, we all know how fanboylike VAG'ers are, they'd argue the Passat diesel was the best handling car ever if they thought they were in with a chance) :p
Relatively speaking though the 2.9 engine is still heavy compared to the rest of the engines in the corrado range and the corrado is a small car..... ;)
The 2.9/3.2 engines weigh about the same I am sure its within 3-5kg but can't quite remember, the Corrados VR6 was never regarded as light sure it was over 1200kg which is heavy for what was a small car. Its the transmission and 4wd system thats attached to the 3.2 that make the current cars very heavy almost 1600kg for a A3 is crazy.
it's closer to 1500 than 1600, and the quattro does add a heap of weight
but it's still a heavy engine, the v6's are aluminium now though so aren't so bad
2.0T FSI - 152kg
3.2 V6 FSI - 169.5kg
Passats handle like a dog. Anyone tell I don't like my car? :( I now have an unjustified negative view of VWs and am skeptical of everything they make.
it was meant to be coming this year but not heard anything about it for ages :(
looked great too imo. well would in black!
I like that muchly :D
VAG is a god amonst car manufacturers, you must worship them. And remember you cant just call them VW, it has to be VAG!
I think I've only seen one person on here refer to VW as VAG, everyone else with a clue will refer to the various members of the VAG group as VAG and/or notice people doing this
How much are they going to be released at?
Going to come in according to the reviews at £1k under the Golf GTI at around 19k, they also come as standard with the magnetic adjustable dampers from the TT. It also sits lower and has a wider track than the GTI all the reviews I have seen have said it handles superbly and a lot better than the Golf GTI.
