Metal Gear Online - The PS3 Multiplayer Thread
Hopefully I will be on then. I actually missed a parade this afternoon because I was too busy playin SP over lunch, my reshow should be over before 2230. Yeah the army sucks!
psn: andy1195
mgo: agent_orange83
Wow, I'm really starting to understand how MGO really works. You have to swap from auto aim and manual aim! Its the only way you'll hang with everyone else. Swawping between the two in the heat of battle is tricky, but once you get the hang of it, you don't think about it.
Almost level 3 on the blade tree. Wanna start cutting throats up.
I honestly don't see the point of using auto aim for any reason. It takes sooooo long to lock on and is pretty low accuracy?
Auto aim with the pistol then swap to a rifle with manual aim. You can hold your own against 1-2 guys at once doing this. Pistol has longer lock on range. Try it out. :)
