- 14 Dec 2005
- Bath
As the title says, I've got a problem
I've recently noticed that sometimes the green LED on my Magsafe connector goes very dim (so dim that it's only noticeable in pitch black, in daylight it looks as if the LED isn't on at all). This only happens once it's been running off the power adapter & fully charged for a while. The MBP still says it's fully charged & running from the power adapter so it seems that the power adapter is still providing power, just not showing the green light
The solution has been to unplug the magsafe connector (and consequently backlighting goes down and it says that it's using the battery) and then plug it back in (backlighting comes back up and the LED lights up green again.)
Any ideas anyone? Is it likely to be the power adapter itself or something inside the mac?
TY
Ed
2.4ghz Santa Rosa MacBook Pro (9 months old but have bought the 3yrs applecare).
....The solution has been to unplug the magsafe connector (and consequently backlighting goes down and it says that it's using the battery) and then plug it back in (backlighting comes back up and the LED lights up green again.)
TY
Ed
