Mouse comfort - Anything better than an MX518/G5
3 Jan 2004
Bournemouth
I'm about to sell my VX revolution laptop mouse for a Logitech G5, the VX is just too small so i need a decent sized mouse. I liked the mx518 and i think the G5 is the same shape
Do logitech do a wireless G5? Or a wireless mouse of the same size/comfort?
Mx revolution is overkill
The wireless version of the G5 is the G7, but you'll struggle to fond one these days.
If your after the ultimate in non-gaming mice, MX Revolution is the way to go. I have one at work and it's superb.
But my home mouse is a G5, I can't have any other for gaming.
i find the way i hold my MX518 really cramps up my little finger, dont know why i hold it so tight :(
Really??? Me too, i have the same mouse too strange...
It really hurts my little finger sometimes, i cant hold it any other way though, the reason i think it is, is because i have large hands :/
Could be, but that's why i chose a large mouse :-/
Also it must be the way i play games cos i have the mx500 at work and nvr get the same pain with that...
If you dont want something that looks like its for gaming, it has to be the MX Revolution or the slightly cheaper VX revolution.
I have the VX revolution, too small
i tried the MX today, it just seems overkill, i suppose it felt comfortable but 2 wheels? a dozen buttons?
ended up with an MX620, testing it out now, its like the VX Revo but bigger, same features etc, just deciding if i like the shape now
G7
I love my Logitech G7 too. It's a really good mouse. One of the greates features is that there are two batteries and one is always on charge while the other is in use.
I just bought myself a second G7 in case the first one breaks, and they are getting scarce as teeth now.
mx here, lovely and comfy, a bit smaller then the donkeys old logitec mousemanwheel wireless it replaced which was hella comfy as I have big hands and it cupped perfectly. mx has loads of butons, but you get used to it.
well for starters it depends on budget.
if you have a good budget then of £30 , get the mx518, ive tried one before and it was better if not just as good as my diamondback and more comfortable. if your looking for a mouse under £20 then i cant see any other mouse to go for expect the razer krait.
