Ip config from a file possible ??
18 Oct 2002
At home
Hi,
I backed up a server using Ghost so can now see all the files. Gone a bit to far to restore the image but forgot to make note of the network ip addresses and stuff.
Know normally I can get to it via registry but how can I get to it via normal files ?
would the ntuser.dat or something be there ??
Thanks.
If you're also running DNS or WINS why not just have a lookie there? Unless off course they were running on the server you've just ghosted :)
Another option is try and ping the server from a machine that recently talked to this server as the details might be in the cache.
thanks but needed to know the ip details of the iscsi device which i had no idea about and there was no documentation anywhere :(
