GX2 > HD4850 Crossfire
Cost less to boot![]()
My 2 Sapphire's were under £240 - how much is a GX2?
Ok, with the card still at 700_2100, no AA and no AF at 1680 x 1050, high settings, I got the following;
Min fps - 23.19
Max fps - 59.24
Avg fps - 48.34
Unfortunately, I never recorded any 8800GT results at that res as I didn't have the monitor I have now.
I just ran one at the same settings Tooks on my 512mb 8800gts with the new drivers.
Average FPS: 32.47
Min FPS: 23.92
Max FPS: 40.37
CPU at 3.4ghz, so a pretty respectable increase for anyone with a 512mb card, im going to go for the 4870 or 4870x2 myself.
Thanks for that, good to see what folks are getting with the various GPU's.
The 4870 should be a beast I reckon!
No it's not.
I went from a 3.6 C2D to 4GHZ C2D and picked up 1FPS at that res. I doubt it makes all that much difference tbh.
It does in 3D Mark, as part of the score is made up from the CPU test.
My HD4850 overclocked to 700_2100 again at 1440 x 900 and with everything on high settings manages the following scores;
Min fps - 31.14
Max fps - 58.37
Avg fps - 47.74
6/21/2008 9:49:05 PM - Vista 64
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1280x1024, AA=No AA, Vsync=Disabled, 64 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: High
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 47.19s, Average FPS: 42.39
Min FPS: 32.43 at frame 1975, Max FPS: 52.01 at frame 858
Average Tri/Sec: 41673792, Tri/Frame: 983199
Recorded/Played Tris ratio: 0.93
!TimeDemo Run 1 Finished.
Play Time: 43.43s, Average FPS: 46.05
Min FPS: 32.43 at frame 1975, Max FPS: 55.06 at frame 991
Average Tri/Sec: 45769640, Tri/Frame: 993874
Recorded/Played Tris ratio: 0.92
!TimeDemo Run 2 Finished.
Play Time: 43.48s, Average FPS: 46.00
Average Tri/Sec: 45734088, Tri/Frame: 994200
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Anyway so far I compiled about 1 hour's worth of stats from Fraps in CoD4 on both my 3850 and 4850 using identical settings
1680x1050, CCC set to max quality, manually selected 2x AA, AF set to app preference and AF slider in CoD4 all the way up
I've got the settings at 8xAA 16xAF now and will start recording statistics for another hour total.
what are the fan profiles like on these cards? hope they're not like the 3850 where the fan barely speeds up even under full load?![]()
just benched 1280x1024 high.... GPU @ 690/1100, E6750 @ 3.64ghz
Run #1- DX9 1280x1024 AA=No AA, 64 bit test, Quality: High ~~ Overall Average FPS: 46.025
I can't quite get my head round some figures I've just generated using the Crysis GPU Benchmark Application. If they are correct, then this HD4850 is amazing...
I'd just run 3dmark06 at default and achieved 14512 marks, barely any more than my overclocked 8800GT managed. Never mind I thought, try the games and see how they go.
Basically, my old 8800GT (512MB) at 1440 x 900 with a quad at 3ghz, running for 4 loops with everything set to high achieved the following scores;
Min fps - 8.94
Max fps - 28.4
Avg fps - 24.15
this doesn't look like such a Crysis killer yet...
Gurusan, what did you do to your old, super-superclocked 3850?
One thing i noticed was your max frames are always just under 60fps, you didnt have v-sync enabled did you?![]()
Did these figures not look low to anyone?
I have just ran the bench on 3 loops, 1680x1050, no AA, all settings on high, and i get the following:
Min fps - 12.4
Max fps - 37.65
Avg fps - 32.145
XP DX9 with spec as sig.
Just trying to decide whetehr the new ATI card is worth the upgrade from the GT. Could someone do a quick test on 1680X1050, High, No AA for me?
