7901 ultra 2 sticks limit!
Has any one noticed that the Nvidia 790i ultra limits you to only 2 gb dd3 ram if you go over 1800mhz.
if you check the list it says you can use 4 sticks of ram for anything under 1600mhz
check it out and tell me what you think gents, if im wrong my bad, but it just caught my eye.
http://www.slizone.com/object/slizone_build_mem.html
Im told the later Asus ones are fine, remember there is 2 types of 790I, think 1 is a Ultra or such.
Thanks 2x DDR3 ram = 2gb it is then.
people have advised me that when using vista 64 you should have 4gb or ram! how does that sit with using 2 gb or ram?
get a 4gb kit consisting of 2 2GB sticks of RAM.
edit: Also, that table, isn't it only displaying the RAM moduels that use EPP? It's not actually the limitations of the board by setting timings manually is it?
from the table: "SLI-Ready DDR3 SDRAM DIMMs for NVIDIA nForce SLI motherboards supporting EPP 2.0"
Yes you are correct, thing is most people dont even run theirs with the EPP turned on..
