I print my own using Decadry cards, they're reasonably cheap and you can download templates. If you do try them don't use anything >200gsm as they'll be too flimsy for business cards
http://www.decadry.com/En/papiers/cartevis.asp
so which gsm do you recommend?Mine are paid for by work now but i have used that Vistaprint place before now
90 gsm ours are
90 gsm? That's paper!
i want quite thickish cards, dont want flimsyso which gsm do you recommend?
If you buy bespoke ones then you should demand at least thatI would say not less than 300gsm...
I have some for work, the ones I have at the mo cost far too much (£40 for 100) so will be finding a new printer from now on.
I've heard so many bad comments about Vistaprint, and they also advertise on the back of the cards, so not a good sign when dealing with a company/
