- 26 Sep 2006
- West Bridgford
Instead of the usual polishing routine, I thought I'd treat the motor to some Dodo juice
and some other goodies
First the standard rinse, wash, rinse.
First departure to the usual was using a Sonus de Wonder towl to dry the car:-
Expensive (£16.95 for 2) but they are (a) very good and (b) massive! 1 towl did an entire BMW 3 series without needing to be rung out.
Next I tried some detailing clay. I used Sonus SFX Ultra-Fine Detailing Clay Sampler
Had a go, certainly was starting to shift some some of the bonded on dirt.
Next I used the Dodo juice!
As the car is black, I opted for Purple Haze
£32.50. This stuff is for dark colours only, and is a soft wax. It was easy to apply, but I think I applied too much as it took ages to remove. I also went through 3 polishing clothes. The end result:-
2 hours well spent.
and some other goodiesFirst the standard rinse, wash, rinse.
2 hours well spent.
