Permabanned
 - 28 Oct 2006
 - Bournemouth
http://en.expreview.com/2008/06/23/...-tool-to-support-hd-4850-fan-speed-adjusting/
Does it work, or is the article also contradicting itself?
FOUND THIS
****NOT WORTH WHILE UNLESS YOU ARE GOING FOR 50% OR HIGHER****
I found the profile here
C:\Documents and Settings\USER\Local Settings\Application Data\ATI\ACE
FOUND THIS
if you make a profile in catalyst after turning on Overdrive( make sure clock and memory settings are correct). You can then go to the file "C:\Users\Bretware\AppData\Local\ATI\ACE\Bretware. XML. the xml file will have the same name as the catalyst profile you saved. right click and hit edit.
<Feature name="FanSpeedAlgorithm_0">
<Property name="FanSpeedAlgorithm" value="Manual" />
</Feature>
<Feature name="FanSpeedRPMTarget_0">
<Property name="Want" value="0" />
</Feature>
<Feature name="FanSpeedPercentTarget_0">
<Property name="Want" value="65" />
Change the value to "manual" and Want value to "65"
Save the file then reload your profile in catalyst.
65% seemed perfect for me, 70% was loud but you may need it if your case has poor air flow.
You will have to select the profile everytime you start the computer, but it will work until there is a fix or better info so i can figure how to change the auto target temp.
Good Luck ,bretware
