Cats 8.6 control centre won't load, suggestions.
21 Oct 2002
Bexhill on sea
Or any cat's CCC for that matter. I've reinstalled me 3870XT and while CCC with the 8.1 drivers will instal and load when needed (installed from a cd), any drivers that are downloaded, 8.3 to 8.6, instal without any prob, I still can't get the CCC to load up.
It would appear that any driver pack loaded from a disc works fine, but any drivers downloaded online have this prob. I've treid numerous drivers and also downloaded the CCC from ati and tried that, but it still won't load. I also don't get the tray icon showing at the bottm right hand side of the task bar, but it shows the CCC option at the top of the window if I right click the desktop.
Usually I've been able to get round this prob by installing from a disc, then updating with the latest set but its not playing ball this time.
I've also had this message, "MOM" or "Cli" file cannot be found so I'm assuming it needs this to locate the CCC and load it.
Can anyone help me with this if possible, cheers :)
download the latest cats (8.6)
uninstall the drivers / package your using at the moment
run driver cleaner
install .net framework 3.5
install the 8.6s
Cheers for the info guys, especially "madness", I was missing net frame 3.5, all installed working fine now, Cheers again:).
