Caporegime
- 9 Mar 2006
- Surrey
Assassins Creed would not be better in first person!
I installed it yesterday after work, only played for a few hours (Got to the citadel.) But I'm having trouble with sounds during some cut-scenes. Its like the sound effects dont work, but the voices do.
I'm using a x-fi music card. My drivers are upto date as far as I know. Anyone else got this problem?
Yep get exact same problem..... guess which sound card i have
Creative Xi-fi
its not too bad as its uncommon and it appears mostly in dialogues. Not sure what the fix is.
Also what selection of NPCS are people adventuring with? i picked the turian and Rex so far. But if im after entertaining dialogue between members who'se do you recommend?
I thought it might be normal as it is a port but it looks like I have something set up wrongNope, something wrong there mate.
So how long did it take everyone to finish the game, then? I've clocked in at 17 hours, 41 minutes, which seems incredibly short. I did virtually every sidequest I discovered, and thought I'd gone to all the different systems and landed on every possible planet. It seems that I've missed a fair bit of it. Level 45, too - what's the level cap? I missed half of the content out of the KOTOR games the first time I played them too, it seems to be a pattern with me and RPGs.
I wouldn't use the 360 pad with the PC version, it'll just be awkward. Especially since BioWare did a good job of porting the gameplay to make full use of mouse/keyboard combo.
I just can't get into it because of third person setup. I find it difficult to get used to running around looking at the back of someone's head. Not only it wrecks the shooter part for me, because shooting in third person view has nothing to do with precision and accuracy and everything to do with ability to adapt to the console like field of view of fly in the corner of the ceiling, but turning and panning with back of my character stuck in the middle, makes me dizzy after a while. Third person view isn't done properly ever since Heretic II. And it's a great pity. Mass Effect would be amazing as a first person game. Just like Assassin's Creed would me much better off as FPS...
That is very short for a RPGFirst play through took me 7 hours. I think i missed a bit![]()
all the upgrades and collectibles are very confusing i don't know what to do with everything what is convert to omni gel for gods sake lol
