I never said the FPS
COD4 was playable for me at that res, but with no AA. And the micro stutters were rare like i said, and happened mostly on out door areas but even then were still quite rare.
For the most part, the frame rate would be at over 50 FPS @ 2560x1600 with no AA and a little AF on the GX2, the rare stutters were mostly just an annoyance.
But once any AA was enabled it became too bad, but it would be ok with some AF though.
Did you try COD4 @ 2560x1600 with 2x or 4xAA + AF? On these settings it's no where near playable. I found once any AA is enabled with that game on that res you run out of memory. Even my 8800GTX handled it better at that res with some AA as it had enough memory for it.
I just wish i could find software that displays how much VRAM is being used by a game. As far as i know theres not any that work with Vista.
