i Did install xp first,then into the bios i went and followed the instructions to the letter regarding the overclocking saved the settings then booted the machine fails to get into windows and just keeps trying to boot.
So after i get back into the bios and i do all the O/C instructions again but this time i set the 1st boot for my dvd/cdrom with win xp disc in,save and exit machine boots and says hit any key to boot from dvd,windows setup now runs,i select partition format drive and windows starts to install i do all the regional settings and put in the xp serial number windows says 39 mins till
completion then i get the BSOD.
After undoing the O/C settings and reverting to normal settings i boot up and windows then proceeds to finish installing.
I have now tried the above with all 7 bios versions including the 1st and the latest from Abit.com
I really do believe i am stumped and would welcome any kind of suggestion or help,Overclockers support could not even tell me the bios version of the motherboard,what they did say was go back 2 if that do work go back another 2.
So not only can i get the O/C to work i am still waiting for a replacement
antec 1200 case which was picked up on monday by city link.
After spending 570 quid i have to say my overclockers experience has not been a happy one
