*** Official 4870 reviews thread ***
just got a HIS4870 and do you apply the 8.6 cat drivers then the hotfix for these cards and also never used the CCC before do i just leave all AA/AF at aplication controlled cheers,my temp is showing at 76 in CCC but 61 in everest
Will work clean or over the top ;)
thanks JAKUS m8 what is the best CCC or ati tray tools.p.s which one ajusts the fan on the card as cant find it on the CCC panel just overdrive
well ive tried 2 games now grid and cod4 with my 4870 and both games getting stuttering through game and even when titles are coming up,cant believe it
yes cleaned it all out,it kept doing it so cleaned cat drivers out in safe mode with driversweeper and installed the fix cat drivers that came out and still the same, not looking good going to try running 3dmark to see what it gets,
Currently there an no 3rd party apps..Ati tt etc, 2 ways but both involve bios flash, (don't panic very simple) and flash to an asus bios and run they smart doctor app ( You may need to force the flash in dos for vendor change)
2nd get Techpowerup RBE save Your original bios and edit the fan profile, simple and reflash in windows with Winflash...5 mins total job ;)
might be easy to you but not me,and why do you have to flash it to a asus bios for,god wished i kept my 8800gtx,
well ive tried quake wars unreal tournement and tomb raider and they play fine no stuttering and run smooth as silk,so its grid and call of duty 4 which are giving me probs the 2 main games
2x Sapphire 4870
