Full Screen Blu-Ray on HD3450
Don
7 Aug 2003
Aberdeenshire
Got a bit of a problem with a new build using a HD3450 (latest drivers), screen at 2560x1600 and playing HD movies using Cyberlink.
The problem is I can't get it to go full screen, it limits it to 1920x1080 centered when I select full screen in Cyberlink. Is there anyway to get it to scale to the full screen in the ATI drivers?
When I go into the Avivo section in CCC the scale to full screen option is greyed out and stick to source is selected.
Try the 'attributes' section under the display itself in CCC. There are scaling options in there as well. The ones under the Avivo section are the theatre mode options if you have more than one screen, for overlay.
Already set to scale to full screen in there as well.
From a bit of Googling this does appear to be the case which is very strange as the standard upscale after the decode shouldn't be a problem. Makes me wonder if it's just PowerDVD.
It's definitely the GPU, it used to work flawlessly on a 8800GT. Might just get a cheap Nvidia 8 series card to replace it.
Using a E1200, whenever I switch Avivo off, it re-enables itself in PowerDVD so I'm assuming the processor isn't up to it.
On the current release of Catalysts and PowerDVD 7.3 Ultra (need it for HD-DVD support). The demo version of Windvd doesn't support Blu-ray playback and looking at the cost of it anyway, I'll be cheaper buying a Nvidia card :p
ha ha, im pretty certain power dvd 8 can be easily modded to run blu-ray and hd dvd, although ive never tried it, power dvd 7.3 ultra is easy to use
just out of interest which blu-ray drive are you using?
i bought the lg hd/blu-ray combo drive myself
That's the one I've got, everything was working fine before with the exception of an Nvidia GPU, but I've put a new PC together for playing music/DVDs and office type stuff so was just going to bung a cheap card in it.
It's not the software.
It's the GPU, the 3000 series will not upscale 1080p Blu-Ray/HD-DVD to 2560x1600.
You can try all the software and drivers you want, but it's not going to happen.
The 4800 series will do this though, with there UVD2. They also support picture in picture (a Blu-Ray 2.0 spec). Something Nvidia have had since 9xxx series.
But a 8000 series will upscale to 2560x1600, atleast a 8800GT and higher anyway, dont know about the lower end ones.
According to Nvidia, the 8500/8600GT is on a par with the 8800GT (which is better than the 8800GTX/Ultra), so might just sling in a passive 8500GT and see how that goes.
do you guys get black borders above and below the image in power dvd using blu-ray films? cant seem to get rid of them even by "stretch to fit to screen" am unable to zoom as they are highlighted out in power dvd 7.3 ultra, soo irritating :(
it stretches fine in all hd-dvds but not any blu-rays
I have a similar problem with my Gigabyte GA-MA78GM-S2H 780G. I’ve connected the onboard ATI Radeon HD 3200 through HDMI to my 27” HDTV, set the res to 1920x1080 but I can’t get it to go full screen, on the normal desktop or playing movies. I’ve tried installing the latest drivers, checked the settings and its not going full screen. Does anyone know what the problem could be?
