Have a separate freeview box attached to an ordinary CRT widescreen TV, with the freeview (plus analogue) aerial up in the roofspace (due to house being in an exposed area with frequent high winds), I also have a feed from the same aerial coming to my Terratec Cingery 2400i DT (freeview) tuner, on a computer.
When the weather is wet or humid, the picture on both the CRT + Terratec (the CRT is usually a bit worse) units suffer from interference, ie some pixelation, but mostly the picture looks as if it misses a few frames. The analogue picture of same channel are fine. At other times the digital picture is fine.
What is the cause of this problem and how do I remedy it?
Thanks.
Thanks.
