What hardware are you running to need a 1000w psu?
This would be the one i would recommend
http://www.overclockers.co.uk/showp...2.2 Modular SLI Compliant PSU (CMPSU-1000HXUK)
It needs to be 1000w
guru3D said:Our test system contains a Core 2 Duo X6800 Extreme Processor, the nForce 680i mainboard, a passive water-cooling solution on the CPU, DVD-rom and a WD Raptor drive. The results:
* PC in Idle = 197 Watt
* PC 100% usage (wattage gaming Peak) = 530 Watt (SLI)
* PC 100% usage (wattage gaming Peak) = 749 Watt (3-way SLI)
Yeah but I might get another GPU and I'd rather be safe. The PSU is something I don't mind putting a bit more to.
Did you ignore the bit about 2 280 GTXs only using 530W ?
Ah well...
.Slight off topic but you just wasted a lot of money on GT280 and you want to waste another a lot of money on second one.
You could get quad crossfire 4870 for less than this lol.... and you will get probably about 200% the performance.
And you mentioned another 280 for tri-sli ....
Am I the only guy having feeling that this guy wants to play Crysis at max settings only and doesnt care about anything else ?.
Thermaltake PSU.
