Would I likely notice a difference?
Its just that the e4300 is too slow at stock, and to run at 3GHz requires slight voltage increase (1.35V), and I would also like to really get power consumption down on my system (idle mostly, that is). Plus using the stock cooler, and its only just keeping it at decent levels temp wise.
Now it seems that the e8400's are doing 3.6 on stock volts generally, which is great because I don't want to adjust voltages and hate bulky cooling, so stock or something small for cooling required.
Do you think it would be enough of a drop in power consumption (if any) and a big enough gain in performance to justify spending the money?
Edit: Also, how high you think the e7200's would get on stock? Or should I not even consider them?
