The neo vortexx looks interesting, kinda reminds me of the first arctic coolers that we all bought back in the Radeon 9800 days!
I'm not sure if the neo vortexx is better than an Arctic Accelero S1 though? will probably have to try them both and see!
FOUND THIS
I found the profile here
C:\Documents and Settings\USER\Local Settings\Application Data\ATI\ACE
Are there any waterblocks for the 4870's around yet ? I'm thinking of converting over to water for some peace and quiet when the 1gb versions come out
I'm tempted by the Neo Vortexx for my new 4850, but it doesn't seem to give any cooling the to VRMs, isn't that a bad thing?
Or could I just whack some aftermarket gpu ramsinks onto them?
Azza, did you make a thread about your new card or installing the Akasa cooler?
I'm interested to see pics and stuff!
Also quick question, would it be quite straight forward to remove the stock cooler, clean away the factory putty and replace it with some premium paste?
I am mainly wanting to know if the thermalpads on the memory are re-usable i.e if I take the stock cooler on and off, on and off again will they still be in one piece?
azza if you clock the card the vrms will get quite hot. mine get scorching. I have a 92mm fan blowing over them though and they stay under about 45c according to a probe.
