I recently built a PC with components bought from overclockers. Until very recently it has behaved well -well apart from a couple of vista niggles- and I have been very pleased with it.
I don't know how/if any of these symptoms are related but its worth having all the available information.
- About a week ago I noticed the occasional random lock up when it was left alone for a while.
- Another boot came up with a bright coloured pattern before BIOS and I had to reset it.
- A little over a week ago I left it downloading some files from iTunes overnight and in the morning whilst the files had downloaded, the PC had again locked up. Having restarted I was able to get back into windows.
Having only switched it on a bit over a week afterwards the PC will now not even POST. I hit the power button, all the fans whir up, and then the machine resets itself and this pattern repeats.
Initially I thought this may be a graphics card or a PSU issue. I now am trying a barebones boot of the mobo with everything disconnected bar the CPU (expecting to hear some beeps from the mobo). Again power on, fans whir up and then the machine resets, never getting to POST and this repeating. I also reset CMOS for this boot.
Has anyone had something similar happen? Any advice on how to proceed would be most appreciated. The next stage will be to reassemble the machine outside of case and start from a barebones boot. I have a feeling is that this is not going to make a difference as I can't see how only now the case could be shorting out the mobo.
My gut feeling is that it may be the CPU or mobo
The components used are:
-Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR Edition" Retail / OcUK Value IP35 Pro Intel P35 Motherboard / 4GB OCZ PC-6400 Reaper Dual Channel DDR2 Kit - Bundle - http://www.overclockers.co.uk/showproduct.php?prodid=BU-092-OK
- Gainward BLISS GeForce 8800 GT 1024MB GDDR3 (now not available on OCUK)
- Noctua NH-U12P CPU Cooler (Socket AM2/LGA775) http://www.overclockers.co.uk/showproduct.php?prodid=HS-002-NC
- Corsair TX 650W ATX2.2 SLi Compliant PSU http://www.overclockers.co.uk/showproduct.php?prodid=CA-008-CS
