Ok first attempt to 3.4 GHz failed on Orthas. Interstingly only cores 2 & 3 fail, cores 0 & 1 are fine. I've upped the vcore to 1.425 which is surely enough. No joy.. Just wondering if there is anything I've not done.
Does Everest or the ASUS software give you readings in Windows for the chipset voltages? I'm not familiar with that board, but I've a feeling that it won't give them. If it doesn't then try both the NB and FSB Term/VTT on about +0.1v above the lowest setting.
what about trying them all at the lowest and working your way up till its stable? Its a lot of effort i know but i cant see any other way...unless you just leave it as is
