Argh, was in the middle of playing and the game just closed :/ How annoying! Can't remember where my last save was but it was a fair way back.
Bleh.
How can you play for more than half an hour on a single tile anyway?!
hello.. region play?!
That's what I meant. You can't detail a single tile until you let other regions develop first. You don't for example plan every tile out to the last dot then go and do the second and 'hope' they work well together.
Anyone running it on this kind of spec:
2.4Ghz C2D, 8600GTM 256Mb, 1440x900?
Im wondering if my MBP can run it... im thinking of ditching my PC!
I kept getting random crashes to desktop with no warning or error message. Which was certainly starting to pee me off as i keep forgetting to save!
But after a little research im pretty sure ive narrowed it down having dual cores. So when you start the game, ctrl alt del, goto processes, select simcity4 and set affinity to olny one core. Thus far it hasnt crashed after 5ish hours. Note you have to set he affinity everytime you start the game.
So am I assuming - for a multi-tile city, you'd do an entire tile having industry, one with commerce and one with housing - and one with residential (for example) and just link them up together?
Im running it on almost exactly the same spec on my laptop, runs fine. A bit of lag at times, but easily playable.
Posty, you don't fancy uploading your massive city to somewhere so we can all take a closer look, do you?![]()
Yes, but there's no reason imo to separate commerce and residential, industry and housing should be separated though.
when doin a multi tile city seperating industry houseing and offices, do you put hi tech industry on a different tile or in the same as the housing?
I've heard high tech is more attracted to residental areas so keep it in the same tile. You also get the benefit of sims not having to travel far to work![]()
thats what ive done so far but ive never played a multi tile city so was unsure, i normaly pick a large square and have everything in that tile.
