More crazy prices - Leadtek this time & worlds fastest card from Leadtek......
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
This is it now, not only is OcUK and Leadtek making very little money we have the latest NV price drop too so combine this with both ourselves and Leadtek making very small margin we can offer you these storming Leadtek deals:-
Leadtek GeForce GTX 260 896MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
Get pulled deeper into the gaming experience than ever before with next generation NVIDIA GeForce GTX 260 GPU. GeForce GTX 260 make games including Unreal Tournament 3, Assassin’s Creed, Call of Duty 4: Modern Warfare and S.T.A.L.K.E.R.: Clear Sky – feel like the real thing. High definition worlds crackle and hum with cinema-quality clarity. Lifelike characters behave with such realistic intensity that your palms sweat and your heart races. Objects react to the forces of nature exactly as nature intended. And with 50% better performance than previous generation graphics processors, you get it all...No lag. No dropped frames. No compromises. Beyond the field of play, the GeForce GTX 260 GPU seamlessly shifts intense processing tasks from the CPU to the GPU. Dive into the latest Blu-ray movie, run the Folding@home protein folding application to help cure diseases, browse your favorite web sites in 3D with PicLens, or transcode video to a personal video player up to 7X faster than the CPU.
- Bus Type: PCI Express 2.0 (Backwards compatible with PCI Express)
- Memory: 896MB GDDR3
- Core Clock: 576MHz
- Shader Clock: 1242MHz
- Memory Data Rate: 1998MHz
- Processor Cores: 192
- Shader Model: 4.0
- Texture Fill Rate: 36.9 Billion/sec.
- Memory Interface: 448-bit
- Memory Bandwidth: 111.9GB/sec.
- API Support: Microsoft DirectX 10 and lower, OpenGL 2.1 and lower for Microsoft Windows
- Display Connectors: 2 Dual-Link DVI-I, HDTV + TV Out
- RAMDACs: Dual 400MHz
- HDCP Capable
- HDMI Capable
- 2-Way & 3-Way NVIDIA SLi Support
- Card Dimensions: 266.7mm x 95.3mm x 38.1mm
- Warranty: 1 Year
Price: £174.99+VAT (£205.61 inc VAT)
BUY NOW!
Leadtek GeForce GTX 280 1024MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail
Get pulled deeper into the gaming experience than ever before with next generation NVIDIA GeForce GTX 280 GPU. GeForce GTX 280 make games including Unreal Tournament 3, Assassin’s Creed, Call of Duty 4: Modern Warfare and S.T.A.L.K.E.R.: Clear Sky - feel like the real thing. High definition worlds crackle and hum with cinema-quality clarity. Lifelike characters behave with such realistic intensity that your palms sweat and your heart races. Objects react to the forces of nature exactly as nature intended. And with 50% better performance than previous generation graphics processors, you get it all...No lag. No dropped frames. No compromises. Beyond the field of play, the GeForce GTX 280 GPU seamlessly shifts intense processing tasks from the CPU to the GPU. Dive into the latest Blu-ray movie, run the Folding@home protein folding application to help cure diseases, browse your favorite web sites in 3D with PicLens, or transcode video to a personal video player up to 7X faster than the CPU.
- Memory: 1GB (1024MB) GDDR3
- Core Clock: 602MHz
- Shader Clock: 1296MHz
- Memory Data Rate: 2214MHz
- Processor Cores: 240
- Shader Model: 4.0
- Texture Fill Rate: 49.2 Billion/sec.
- Memory Interface: 512-bit
- Memory Bandwidth: 141.7GB/sec.
- HDCP Capable
- HDMI Capable
- Warranty: 1 Year
Price: £259.99+VAT (£305.49 inc VAT)
BUY NOW!
Leadtek GeForce GTX 280 Extreme 1024MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail ****Worlds Fastest GTX 280****
- Core Clock: 738MHz
- Shader Clock: 1666MHz
- Memory Data Rate: 2520MHz
- Shader Model: 4.0
- Memory Bandwidth: 151.7GB/sec.
- HDCP Capable
- HDMI Capable
- Warranty: 1 Year
Price: £329.99+VAT (£387.74 inc VAT)
BUY NOW!
Leadtek GeForce 9800 GX2 1024MB GDDR3 TV-Out/Dual DVI/HDMI (PCI-Express) - Retail
Beautifully designed and engineered for extreme power, the Leadtek NVIDIA® GeForce® 9800 GX2 1GB graphics card is The Console Within - a complete, high definition entertainment and gaming solution for the PC. With NVIDIA HybridPower™ technology and two on-board GPU's, the Leadtek NVIDIA® GeForce® 9800 GX2 is bar-none the fastest graphics card available and up to 50% faster than GeForce® 8800 Ultra. When paired with an additional Leadtek NVIDIA® GeForce® 9800 GX2-based graphics card and an NVIDIA nForce® 7 Series motherboard, this Quad NVIDIA SLI® technology solution creates the most awe-inspiring, screaming fast gaming platform to date. Be blown away by scorching frame rates, true-to-life extreme HD gaming, a picture-perfect HD DVD and Blu-ray Disc® movies with ultra-smooth playback.
- GeForce 9800 GX2 core running at 600MHz
- Shader Clock Speed of 1500MHz
- 1024MB GDDR3 Memory running at 2000MHz
- 512-Bit Memory Interface
- 256 Stream Processors
- Shader Model 4.0
- Texture Fill Rate: 76.8 billion/sec
- Memory Bandwidth: 128GB/s
- Up to 50% faster than GeForceR 8800 Ultra
- Display Connectors: 2 Dual-Link DVI-I, HDMIR Out
- HDCP Capable, HDMIR Capable
- Designed For Extreme HD Gaming
- Nvidia Pure Video Technology
- Dedicated Video processors free the GPU Shaders to run 3D applications
- Dual dual-link DVI supports two 2560 x 1600 resolution displays
- HDCP Enabled!!
- SLI ready
- True High Dynamic Range Rendering Support – Based on Open EXR technology
- World's first unified architecture supporting Microsoft® DirectX® 10
- Built for Microsoft® Windows® Vista™
- 2yr Warranty with Leadtek/OcUK
Note: This card is 295mm in length so make sure it fits in your case! Also the cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 600W minimum for PSU and 700W+ is recommended. Also make sure your PSU has true 8 pin PCI-Express connector rather than a 6+2 pin connector.
Price: £199.99+VAT (£234.99 Inc. VAT)
BUY NOW!
The Leadtek 9800 GX2 deal is limited stock, we have 1000pc arriving next Friday, once this 1000pc are sold thats it we can't get any more. So if you want one then get your pre-order in because at this price they are an absolute steal for the raw performance they give. :)
Oh my god, that 9800GX2 price makes it very tempting.
I was going to hold out for the 4870X2 but now I dont know, this is less than the 4870X2 will be right?
The only game I play is COD4, would it be worth the upgrade from a 8800GTS 512, I game at 1920 x 1200.
HI there
Yes 4870 X2 will cost more and when 4870 X2 comes out all 9800 GX2's will be gone. Leadtek are loosing big money on these by selling them to us so cheap, hence why stock limited.
Awesome!
What are Leadtek cards like, by this I mean, are they good quality, reliable cards which don't die every 5 minutes.
I went from an 8800GTS 512 to a 9800GX2, and I run COD4 at all maximum in-game settings, 1920x1200. It ran very well in my GTS, but a large amount of smoke on screen would slow it to a crawl. With the GX2, the frame rate remains consistently high all the time.
It's not a necessary upgrade, more the icing on the cake.
Awesome!
HI there
One of the better brands reliability wise and one of the longest standing NVIDIA partners. So there product quality is excellent as is there packaging. :)
I would buy *** GX2.... but it won't fit in my friggin case unless I remove the drive rack, which I obviously need for drives :(
Same with every flippin high end nvidia card :(
I certainly like that Gx2, infact I'm very very tempted to get one and sell my 2x8800GT's onwards... MMMmmmm let me think about it...
Cheers Pug
