Dusty Graphics Card
PCB cleaner or compressed air. Compressed air if it's a light dusting and PCB cleaner if it's absoloutely baked on.
No joke, you CAN use a vacuum, but be very careful not to actually touch the nozzle onto the PC's components as there might be static on it. Sucking doesn't really do as good a job at shifting big lumps of dust as blowing does, so what I usually do is huff and puff into the case for awhile and then vacuum up all the big tufts of crap that have fallen back into the case.
For cleaning the fins of fans and the space in-between heatsink fins I use cotton buds.
I'm quite lucky, I have an air compressor that I use for dusting out.
How much did that set you back? I'm pretty sick of blowing into my computer case and inhaling all the dust I dislodge, but cans of compressed air tend to be expensive imho.
Thanks for the suggestions guys, i wanted to ask something else completely off topic to this thread but may aswell ask here instead of making a new thread, i had a go at overclocking my 9250 today and only increased the core/memory around 10 mhz, is it safe to carry on?, im using ATI Tool.
