A big online game store has each for 7.99 free delivery and if you go via quidco can get 11% off to.
The place where the logo is a dog looking into the record player had it and the expantion for £4 each last month.
HELP!?
my cd's are fubar - so i downloaded from the Blizzard (free if you register your key) and when trying to install it asks me for a 24 digit key xxxxxx-xxxx-xxxxxx-xxxx however the key on the front of my Diablo 2 box is 16 digit xxxx-xxxx-xxxx-xxxx
can anyone help?
is this worth it ?
Diablo 2 + Expansion (from blizzard site) £18.99
Just started playing this toady and made a flavour of the month barb
Is dual weld the best way to go ?
Does anyone here have the original version of Diablo, shipped in one of the old-fashioned cardboard boxes PC games used to come in? I'm trying to find my CD key but can't find it anywhere on any of the manuals or things that came in the box (that I can find). Can anyone tell me where it should be?
difficult question to answer, theres a few options with Barb builds, usually revolving around frenzy or whirlwind as the main damage dealer. .
You lucky sod
Where'd you get the SOJ from?
Also, if anyone has a shako, i'd be more than willing to free up your valuable stash space![]()
