Loud Electrical Spark Noise From PC
  • Thread starter Thread starter ray
  • Start date Start date
ray
ray
18 Oct 2002
Hi everyone,
A loud noise, which sounded just like an electrical spark, came from my PC last night but everything is working fine. Should I be worried? It's the first, and only, time it's happened. Will it have come from the PSU? It's a Seasonic S12 600W model and it's around 1-2 years old.
Thanks in advance! :)
1st thing i would do is unplug the pc from the power supply , earth your self to side of the case or radiator etc to release any built up static and remove the side casing .
Thoroughly check all the connections and wires for any damage or loose wires. Also check for any damage or loose connections on the input socket at the rear of the power supply ( outside of case ) also check mains lead.
If you dont already make sure you have a good quality surge protector connected to your pc
Also make sure everything is secure inside your case and screwed down securely.
Are your pc components dust free ?
Could it not be a speaker setup that caused the noise?
The amount of time my girfriend has turned my setup off at the wall before turning them off properly I wonder why it hasn't done damage as a huge pop/sparky sound occurs..
Thanks for all the helpful tips, everyone! :) The machine is receiving power from an APC UPS, I've not found any loose connections and there isn't much dust inside. If the noise did come from the PSU, does it mean it's about to die? I've not heard that noise since.
If the pc is still working fine then a loose mains cable into the psu would be my bet, power down and make sure it is firmly pushed into the psu, if using a ups double check the cables at the ups too. I get this all the time from testing equipment at work.
