Wireless Adaptor for Vista x64?
26 Jun 2008
Does OcUK have a Wireless adapter that works with Vista x64? I bought a Linksys WUSB54GR 54Mbps RangeBooster Wireless USB 2.0 Network Adapter with my new system but for reasons that are unknown to me, i forgot to check for 64bit support, and just assumed it would be there.
Well its not, and im trying to find someone on OcUK that is but so far ive not had much luck in confirming anything eitherway.
Help?! :confused:
A lot of the Belkin ones have Vista 64 drivers, have a look on their site.
On your head be it! I dont trust belkin, and if you do go with belkin a lot of the adaptors have different versions and therefor different drivers so is still a bit of a gamble on which version you get.
A thread like this comes up fairly often, I always recommend the
Netgear WG111T as its the only USB one i know off the top of my head that has 64bit drivers.
