Q6600 users what's your vid
1.168v while doing some encoding.
Ok, no more showing off now.
mines lower 1.1625 :) did a post here a while back with screenshot but i can't be bothered to look :)
Mines 1.2625, have mine running at 400*8, 1.31v (or something close to that) in the BIOS.
Could get higher but I sort of got bored with playing around with it. :)
Yours can probably be confirmed as a SpeedStep issue.
But I'm still a little dubious about his.
But for a lapped cpu and a s1283 heatsink 72c under prime is bad.... and there is a 8-9c difference between cores. However it's better than it was before it was lapped :eek: (Cheers W3bbo and yes it's properly fitted :p)
:eek: If that VID is real.
I have to use 1.46vcore (windows) for 3.6GHZ, crappy 1.3125 VID :mad:
It is pretty good that. I need 1.45v windows and 1.41v load to get my 1.25vid stable at 3.6Ghz.
So yours is a pretty good overclocker. Shame about the core temp differences though and your lack of adequate cooling.
