New fancy apps for N95 8gb?
4 Feb 2003
West Midlands
I know there are existing threads but im curious if people have come across any decent apps lately? My new addition is Garmin XT - awesome for satnav :)
there is now an unofficial fix so tomtom will work with the internal gps. garmin has since been deleted from my phone
am i being blind or is there no PM option on here?
i'm not too sure on the rules for posting links to the kind of site i found it on so was gonna PM it :?
Nokia Sports Tracker (does what it says)
Handy Wi (Wifi Scanner)
Rotate me (Rotates screen Iphone stylee)
Nokia Internet Radio (Internet Radio)
cClock (Standby clock enhancement)
S60Spoton (handy to use your phone as a torch)
Slick (IM Client)
Mastergear (Mastersystem Emulator) **Not free**
Slide Hangup (Makes your phone answer call on slide up and hang up on slide down)
Super GoBoy (GBA/GB Emulator)
Profile Scheduler (Changes profile based on time)
Lightsaber (turn your phone into a lightsaber)
Google Mail client
Should be able to find all these using google all are freeware apart from Mastergear.
Also would be interesting to hear about this Tom Tom on N95s :)
^^ i found tomtom calculate routes quicker when you decide to go the wrong way :) not used garmin long enough to notice anything else major
Had a bit of a look regarding Tom Tom on the N95,
Seems to use it you have to start a program then start Tom Tom and then re do the settings every time you use it.
Seems like a bit of a faff on
